Any alternative to naviate rebar for revit 2023
chix88
chix88
not sure if i am allowed to make the same post in two forum , but i was not sure where to post it so:
is there any alternative to naviate REX, since it's no more an add-in, and the naviate 2023  is kinda not complete , it can't rebar the footing, only beam wall and column.
thank you
Why can't you rebar footing?  I have no such problem. It's easy, peasy here.
chix88
sorry didn't understand your reply
- do you mean you have no problem rebaring footing with naviate?
because i don't have the option to rebar footing in his newer version
- or you mean that it' easy to rebar footing without the naviate addon ?
yes i know it' easy, just wanted to have a tool to make it easier.
thank you
Alternates are:
  1. placing rebars in Revit
  2. Model footing as structural beams or structural walls so that you can use the add-in
