Announcement: Revit 2019.2 and Revit LT 2019.2 Updates have been released 1/16
Viveka_CD
Alumni Alumni
Message 1 of 24
Viveka_CD
Hello, Revit customers on Subscription and Maintenance plans,
Please read Revit Blog post on Revit 2019.2: Revit 2019.2 new features connect data, cloud, and customers released January 16th, 2019 and check out the new features highlighted in this blog!
Product Updates for Revit 2019.2 and Revit LT 2019.2 have been released.
Please Install from your Autodesk Desktop App or by signing into your Accounts portal.
NOTE: Please see this thread (post 35/37) for a workaround and detailed information regarding any issues with the update.
If you have any questions, please let me know!
Replies (23)
Message 2 of 24
gbiallas
So the Revit 2019.2 Update doesn't seem to work. My Revit build number remains 19.1.0.112 after applying the update. Any idea when we should see a working update?
Message 3 of 24
Viveka_CD
@gbiallas
Can you please try a complete reboot and check if this resolves the issue?
Message 4 of 24
gbiallas
No change after rebooting.
Message 5 of 24
Viveka_CD
Hi @gbiallas
Please see the response from @Tony_Michniewicz on this thread and let me know if this helps!
I'll check if the team has more input on this issue.
Thanks!
Message 6 of 24
gbiallas
Yep, I'm also on that thread and had not luck with Tony's solution either.
Message 7 of 24
Viveka_CD
@gbiallas
Can you confirm if you've downloaded from manage.autodesk.com?
Message 8 of 24
gbiallas
Yes, I did because the update was not showing up in the Autodesk Desktop App on all of my work stations.
Message 9 of 24
Babak-OJB
Observer
Observer
I have downloaded and installed Revit 2019.2. It works perfectly fine.
The only thing that seams not to function is SITE DESIGNER tool. I have uninstalled and reinstalled. I have rebooted couple time with no luck.
Can anyone provide more information to solve this issue?
Message 10 of 24
Babak-OJB
Observer
Observer
Why is Revit Site designer plugin doesn't show up in the ribbon bar?
Revit Version: 2019.2
Message 11 of 24
Kev_D
I have also updated to 2019.2, but my build number is still 2019.1.
Message 12 of 24
Viveka_CD
Hi @Babak-OJB@Kev_D@gbiallas
Waiting for further updates from the team, Please uninstall and reinstall Revit 2019 and then apply the 2019.2 Update directly.
Message 13 of 24
Tony_Michniewicz
For those of you that are having problems with the installation of the Revit 2019.2 Update, we've identified that this problem occurs on systems that had the Revit 2019.1 Update installed first and the Revit 2019.0.2 Security Fix was applied later.  The Revit 2019.0.2 Security Fix failed to block this unsupported update path, which leaves Revit 2019 in a bad state.
We are investigating better work-arounds but at this time the only known solution is to uninstall and reinstall Revit 2019, and then apply the 2019.2 Update.
Tony Michniewicz
Revit Software QA Analyst
Message 14 of 24
dbehner
Is anyone else experiencing the project browser rest its width after the update?19.2 bug.jpg
Message 15 of 24
Babak-OJB
Observer
Observer
Hi Tony,
I followed your recommendation. I uninstalled 2019 revit, and just in case I also cleaned up all registries. After all was don I restarted my PC.
I downloaded revit 2019 again and reinstalled it. After finishing I clicked on the 2019.2 link and reinstalled 2019.2 update. All works well as it did before.
The only problem that I have is for the Site Design plugin to show up in my ribbon bar.
I really need this to work. Has anybody have a solution for this?
Message 16 of 24
Viveka_CD
Message 17 of 24
David_Knight
So this patch will be fixed so it run's correctly, right?
I have no intention to uninstall revit and reinstall revit on all our work PCs.....
Message 18 of 24
huotger
We've identified that this problem only occurs on systems that had the Revit 2019.1 Update installed first and the Revit 2019.0.2 Security Fix was applied later.  The Revit 2019.0.2 Security Fix failed to block this unsupported update path, which leaves Revit 2019 in a bad state.  We are investigating possible solutions to place the installed Revit 2019 back to a support state, but at this time the only known solution is to uninstall and reinstall Revit 2019, and then apply the 2019.2 Update directly.
If you do not have the above scenario, then the Revit 2019.2 Update is expected to apply without issue.
Gerry Huot
SQA Manager
Message 19 of 24
BHamlet
Is there an easy way to determine which state our current install is in besides trying to install the 2019.2 to see if it breaks?
Message 20 of 24
huotger
If you applied Revit 2019.1 Update the below registry key should have a DisplayVersion value of 19.1.0.112.  If the value is 19.0.20.1, than it is likely that Revit 2019.0.2 Hotfix has been attempted to be applied.
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\0A4B643700910150000007C5D0680240\InstallProperties
Gerry Huot
SQA Manager
