Annotation Tag Gets Family Elevation
Hi there,
I am attempting to create a family of Annotation Tag which I hope it to be able to retrieve
the elevation value of families in the project model, but I seem to get stuck now
Please take a look at the attachments to better understand how my problem is
Hope someone can help me out
Thank you,
Nguyen Duy Hoa
tuuletin
Hello, dear,
it is impossible to take parameter "elevation" from generic family to a tag. Thanks, autodesk! Cat Indifferent
But you can create shared parameter "elevation mirror", and copy the value from "elevation" to "elevation mirror" by means of dynamo script (very-very easy to do this).
Hello Tuuletin,
Thank you for you answer and sorry for the delay in replying
Yes indeed, as far as I understand, we can programmatically have this task done by means of Dynamo script or Revit API. Just because I wanted to keep it simple possible so that every Revit users can work with. But I seems I have no choice
I finally had it done by Revit API and I think it is worthwhile sharing here for those who are in the same need
And I think this post should be marked as a solution for a conclusion
Procedure:
1. Create a Sharea Parameter named "ELEVATION"
2. Copy value from "Elevation" parameter to "ELEVATION" parameter (this step is programmatically handled by the below code)
3. Create a Tag Family with a label associated with the "ELEVATION" parameter
Thank you,
Nguyen Duy Hoa
Here is the code for handling step 2:
public void TakeElevation(Autodesk.Revit.DB.Document doc)
            // 1. All Generic Instances
            ElementCategoryFilter filter = new ElementCategoryFilter(BuiltInCategory.OST_GenericModel);
            IList<Element> instanceList = new FilteredElementCollector(doc).WherePasses(filter).WhereElementIsNotElementType().ToElements();
            // To select and count instances at completion
            IList<ElementId> toSelect = new List<ElementId>();
            long count = 0;
            // 2. Conditioned Instances
            foreach (Element ins in instanceList)
                double elevation = 0;
                IList<bool> flag = new List<bool>();
                bool heightIsAvailable = false;
                bool BasedLevelIsAvailable = false;
                ParameterSet paramSet = ins.Parameters;
                foreach (Parameter param in paramSet)
                    if (param.Definition.Name.Equals("Elevation"))
                        elevation = param.AsDouble();
                // The separation of the two loops is necessary to avoid confusion in taking parameter value
                    if (heightIsAvailable = BasedLevelIsAvailable = true && param.Definition.Name.Equals("ELEVATION")) // "ELEVATION" is a custom instance parameter"
                        using (Transaction t = new Transaction(doc, "Set parameters value"))
                            t.Start();
                            param.Set(elevation);
                            t.Commit();
                            count += 1;
                            flag.Add(true);
                if (flag.Contains(true))
                    toSelect.Add(ins.Id);
            // 4. Report
            if (toSelect.Count > 0)
                MessageBox.Show("Executed on " + count + " instance(s)", "Information");
            else
                MessageBox.Show("No instance executed");
            UIDocument uidoc = new UIDocument(doc);
            uidoc.Selection.SetElementIds(toSelect);
Here is the result:
rodrigo.bezerra
@Anonymous, congratulations on your accomplishment.
Do you mind explain in details how to make it work? Is it a macro? Is it C#? Not everyone of us understand programming.
Rodrigo Bezerra
sam_safinia
Thanks to share the code. I tried few ways but not working. Can you please explain more when and how run this API code? Cheers
hello, i used this method and i am having an error in the message box like the picture below. anyway i can solve this please?
