Annotation Symbol Visibility - Height
tdaltd
tdaltd
How do I get my annotation symbol, in this case a light switch, to appear in my RCP drawings regardless of where I set the RCP cut plane.  As it stands, I must add a plan region around every switch locations with a lower cut plane to make the annotation visible.  I want to keep my RCP cut plane above my door heads which is a few feet higherthat the switches.Closet Light and Switch.jpg
pessi.symb
You can nest your symbol in your family and align it to a plane with a controllable height. Assign a parameter to that so you can control the symbol height in your project
handjonathan
Hi @tdaltd
Thanks a lot for posting your question to the forums!   Has the solution suggested by @pessi.symb helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
tdaltd
I cannot get the annotation symbol to stick to the parametric plane. The symbol sticks to the height associated with the actual family (above the reference plane).  If I move the light switch above my RCP cut plane, the symbol appears.   Similarly, if I place a switch above the floor plan cut line, the symbol disappears.  Is there a way to get the symbol to appear in any view, between its upper and lower limits?  If I don't want to see it for some reason, then I can turn it off as an electrical annotation, correct?
azad.Nanva
use the model line to cover all the height of your room.
or post your family here.
