Annotation size change
cadedu22
cadedu22
Hey,
Is there automated way to Change size of all annotations at once?
Like drawing is 1:100, but all Annotation sizes are 1:50.
RDAOU
@cadedu22
You will need to create a new type  and swap them...same for the grids
cadedu22
Gotcha, need to change everything manually.
syman2000
If you don't want to change the annotation, you can set the drawing as 1:50 and then print half-size print to get to 1:100. Most often this is how I achieve the half size annotation without doing too much work.
cadedu22
Yeah, at start was thinking about same solution, i was hoping that there may be is such future already to avoid messing with printer.
