Annotation showing in wrong order in sheet
Hi everyone,
I am facing the below issue once i export the sheet from Revit to CAD the + sign of level moves to the end of the number how i can solve this issue and is it from Revit or CAD, check the belo0w pictures.
Nawar
Sahay_R
@Anonymous - Take a look at the settings shown here - do you have the elevations set up like this?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
It could also be controlled via the Primary Units in AutoCAD that it's mapped to.
Yeah I have checked that and already showing the  + value.
Actually i found out i need to change the text style, so this issue is linked to autocad more than revit
