I cannot upgrade STL exporter 2018 to 2019?
1 ANTWORT 1
Nachricht 1 von 2
martijnbeemsterboer
466 Aufrufe, 1 Antwort
Hello there,
I am using the student version of Revit 2019. I am an architecture student and I want to try to 3d print a model. Therefore I need the STL exporter 2019. Recently I have managed to download the version 2016 and 2017, but they are not showing up in the add-ins tab. I upgraded the version in to 2018, but still it does not work, because I need the 2019 version. I cannot upgrade the 2018 in to 2019, while others can, why is that? Could you tell me where I can find this update, or where I can download the STL exporter 2019? It also did not show up in the appstore.
I tried restarting, sign off sign in, etc. Please help! Thanks!
1 ANTWORT 1
Nachricht 2 von 2
L.Maas
als Antwort auf: martijnbeemsterboer
Typically the add-ins are for a particular revit version and will be installed in folders for that particular versions and therefore normally will not work in other Revit versions.
I am not sure about the student version of Revit. But have a look in the Autodesk Desktop App
Louis
Please mention Revit version, especially when uploading Revit files.
