Annotation line width
yes_and_no
Message 1 of 16
yes_and_no
I tried to increase annotation line width.
It seems to only be able to increase to .39mm.
After that (limit) nothing changes
Am I correct ?
Replies (15)
Message 2 of 16
What for?
Message 3 of 16
yes_and_no
I might have used wrong term, perhaps line weight or line thickness...
Message 4 of 16
Message 5 of 16
yes_and_no
You didn't read my question?
Message 6 of 16
What specific elements do you want to alter the line weight in your project?
Message 7 of 16
You didn't read my answer?
Message 8 of 16
RobDraw
@yes_and_no wrote:
Am I correct ?
No.
Rob
Message 9 of 16
yes_and_no
We do asbuild plans that have HVAC ducts.
Without engage ourselves in documentation non-architecture items in detail,
we do want to show approximate duct size, without actual doing revit ducts
nor double-line drafting ducts where we can be held responsible if one
measures them on revit files. Current solution is having main duct in
single line, in widest weight (~18" in 1/4" scale) and branch duct at less
weight scale.
It happens on my project the main ducts are 48", 36", 24", all wider than
default #16, which is .039mm. I tried to increase the line weight without
success.
Message 10 of 16
RobDraw
I thought you were talking about annotation lineweights. What do as builts and ducts have to do with your OP?
Rob
Message 11 of 16
Those are not annotation lines.  Annotation lines are text leaders, tag and symbol lines, title block lines.
Message 12 of 16
RobDraw
@yes_and_no wrote:
After that nothing changes
What is this "nothing" that changes?
Rob
Message 13 of 16
mhiserZFHXS
You really need to do a better job at explaining yourself from the beginning... This is a recurring issue you're having. The fact that you respond with smart*** comments to people that try to provide some help based on the little info you give doesn't help.
You can include disclaimers in your Revit model that clearly state that the model is not to be used for exact measurements to clear up this whole issue.
Message 14 of 16
yes_and_no
similar to this, duct lines are single annotation lines (nevermind the dimensions)
Message 15 of 16
They are NOT annotation lines unless you draw them directly on sheets.
Message 16 of 16
RobDraw
Are you drawing lines over your ducts? I know you said that but I didn't think that you really meant it.
Rob
