Annotate IFC elements (ProvisionForVoid)
indiana_j0nes
indiana_j0nes
Hi there,
I was wondering if there is a possibility to annotate a IFC element in Revit.
I have imported and integrated ProvisionsForVoid elements into my model, and am looking at possible ways I can annotate them.
Upon Import, the IFC element is a Generic Model element.
Am I thinking completely wrong?
Cheers, K
Kunal Tuljaram Gaidhankar
RDAOU
@indiana_j0nes
In principle yes you can. IFC are exported with a shared parameters txt file...Create a Multi-Category tag and add the a label for the shared parameter you want to tag annotate.
When you export the IFC make sure that:
  1. You added the necessary shared parameters to the VoidProvision Element which you have created
  2. Make sure to schedule those provisions and include IFC as a prefix to the schedule header
  3. Make sure to check "Export Schedules as Property Sets" and "Export only schedules containing IFC in the title"
indiana_j0nes
Hi@RDAOU
Thankyou for your quick reply.
Well, I understand the workflow for Shared parameters I created in Revit and then want those to be exported to IFC.
I need to schedule those parameters and then in the IFC export settings need to export this schedule as Property Sets. Sure that part I get.
That said, how do I get a annotation family in Revit to report the IFC parameters from an IFC File?
I have a IFC link I would like to annotate in my Revit views.
I mimicked the IFC Parameter as new shared parameters and now I got a doubling of those. I am definitely doing something wrong here.. Check the image below:
RDAOU
@indiana_j0nes
The IFC should come with a shared parameters txt file...you do not need to mimic them...you just need to add them to your project/tag
Once you link the IFC into the host model and save it...check the folder under which the IFC was saves ...then use that SP file to add what you need to a multicategory tag
indiana_j0nes
Thanks for the detailed reply @RDAOU
The IFC is exported from an Non-Revit program, forgive my ignorance, but any IFC-Export must have this option to export the parameter right?
Let me try asking for that from our consultant .
Cheers, Kunal
j.vidalNBMS7
Observer
Observer
But this is exporting for IFC from RVT, or also, with IFC files linked or added in RVT and then exported to IFC?
