Angle from true north
TasnimTarannum
TasnimTarannum
Is it possible to get angle of its orientation against a vertical line from north to south. Like spot coordinate.
JasonLLINDNER
u can switch view to True North and add a vertical line then place an angular dimension between that line and any a component which has a side parallel to project north. This serves same purpose in indicating true north and any other angle as spot annotation does with coordinates.
TasnimTarannum
I am doing that but requirement is automated angle like spot co ordinate the it shows North East value same way the angle will show along with north south value
RDAOU
@TasnimTarannum
You can use a parametric north arrow modeled in a generic annotation family see steps below
  • Associat the arriw with an angular parameter "True North" (Type parameter considering that the true north will not change from one view or sheet to the other)
  • add a lable with the parameter above
  • load into project
  • Place an instance(s) where needed
  • Go to the site plan and select the project base point >>> copy the angle to true north
  • Select the generic annotation >> Edit Type >> past value into the "True North" parameter >> hit ok (you can replace this step with a 4-5 nodes dynamo graph)
it should then populate everywhere you placed that annotation and on/in any future annotation you place
PS: you would need to create new types for
  1. new sites if you have different design options each in different location
  2. and a type for the site plan which in most cases is set true north vertical upwards ie: angle value in this case is 0 degrees
TasnimTarannum
Thank you for your response. I’m not very skilled in Revit, so if you could elaborate a bit more, it would be very helpful. I understood how to find the true north angle and opened the generic annotation template, but I couldn’t find any such parameters in the label field.
Why don't you:
- switch the plan view orientation to True North
- place a North arrow symbol family on the line you want to report, the North arrow pointing North
- place a angular dimension from the North arrow to the line
- switch the plan view back to Project North?
RDAOU
@TasnimTarannum
You need to create it.
My Christmas gift to you...Try the attached family (Generic Annotation) you can add it on 1 sheet then copy/paste to selected views >> select sheets with floor plans where you need to place the arrow. The angle is a type parameter ie: changing it once will change on all sheets. It has 2 types:
  1. Site views on sheets (where north point usually always UP/Vertical ie: 0)
  2. Floor Plan View on Sheets (Where usually project north is used . You will enter the Angle to true North you copied from Project base point into this type)
  3. If you have several site (ex: several design design options or from different linked topo/site files) you will have to create a new type per Site/DO. If not, simply disregard this step
Alternative to placing on the sheet and/or placing an instance every time you create a sheet, you can nest it into the Title Block and map the Angle Parameter to the Title block.
