An unrecoverable error has occurred. The program will now be terminated.
I run OS X Yosemite with Parallels and Windows 7. I installed Revit 2015 (Education).
When I poen Revit all works fine until I open a new project and a errormessage appere; "An unrecoverable error has occurred. The program will now be terminated. All of your data has been recently saved, so there is no need to create recovery files."
I have tried to reinstall revit wit no luck.
Are you looking to create a new project or open an existing project? if it is the latter then it could be something to do with the interoperability of that file. Is it the same version as the one you are working in? it could also suggest that the file is corrupt.
sometimes installing latest updates can help.
