An unknown error occurred while accessing central
Shelterwerk
Observer Observer
Shelterwerk
Observer
Observer
Hi Everyone,
I am having issue every time i try to sync from Central. Autodesk software are up to date.
I am the only one having this issue and it happens to multiple projects.
I attached an image of the error i am having.
OS: Windows 10 Build 19042
Thank you
Revit_Whisperer
This appears to be a central file on your local server somewhere...if you are the only one having an issue I would try the following:
Make sure Revit is fully updated
Delete or archive your current local file and its associated backup folder
Launch Revit and browse to the central file location to pull a fresh local file.
