altimetric quota in elevation
Hello to everyone,
I would like to know how and if it is possible to change the units of the altimetric quota that is on front of the elevation, like the ones that are showing on the picture that i am uploading above.
Best regards
Levels can reference Project Base Point and/or Survey Point
...Additionally, Level Heads can be assigned Parameters -- both Family and Shared Type.
@barthbradley, but that isn´t waht I am talking about... My problem isthat the level that I created on the elevations, didn´t appeared on the project browser
Ilic.Andrej
When you copy levels, you don't create the associated views, just the levels. The associated views are automatically created when using "level" tool.
To create a view which should be associated with a particular level, go to view/plan views/floor plan
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
