Alternative to Transfer Project Standards
If I make a new wall type, is there a way I can make it always load up in a new project automatically.
Instead of opening up an old project that uses the wall and 'transferring project standards' over to the new project?
Thanks!
aRcHiTeCt.JM
... hi @Anonymous
… of course you can
… you can create your own template
How-to-create-a-Revit-Template-from-an-existing-project
… you can have or add all components pre loaded as you need / want
... walls, floors, curtain wall, furniture, windows, doors, etc
how to create revit template
... or you can create a specific project template
... with all codes and pre design elements / components from your office
... Revit-Customize Template
... here is a very easy and clear way of creating one
... Setup_a_Revit_Template_from_Existing_Project
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
you can create a particular project template as well customise the families and other settings
https://www.youtube.com/watch?v=ejCXIPukq-A
