All other objects not visible when in Group Edit?
Liselotte_LLA_Link
Liselotte_LLA_Link
Hello
In one of my models all context disappears when I want to edit a Group. This is new - last week it worked normal. Any suggestions to get my underlaying elements back in the View out there?
RDAOU
@Liselotte_LLA_Link
It still works as normal as it can get. All gets half toned but nothing really disappear.
  1. Check that you have the latest build of the Revit version you are using / all updates and hotfixes installed
  2. Check that the GPU's drivers are up to date to rule out the possibility of a graphic glitch due to outdated drivers
Liselotte_LLA_Link
It absolutely doesn't work as normal as it can get.
This is a very large healthcare project with a lot of models. Only this model started this behaviour this week, the rest are performing normal in Group Edit Mode. It's not only Group editing, it'a all editing - masses, stairs .... etc., no visible underlay at all.
RDAOU
@Liselotte_LLA_Link
So that tells us 1 things...The issue is model related (considering that at my end it works fine and in other models at your end it works fine as well)
Question
  1. Are all users having the same issue in this model or only specific users?
  2. Assuming it a workshared model , is it Cloud or Server based?
  3. Did you consider detaching with audit + recreating a new central)
Liselotte_LLA_Link
Yes, model related issue in a Cloudbased model.
All users have the same issue.
.... detaching with audit + recreating a new central! I was really hoping another solution would show up. But we will try that next week if we can't solve the issue 🙂
RDAOU
@Liselotte_LLA_Link
You can try closing the Revit session, clearing collaboration cash, launch Revit and open model from cloud to recreate a new cashed local...this sometimes resolves such issues
