Colour Fills calculation failed Revit 2021
2 ANTWORTEN 2
Nachricht 1 von 3
sham.summan
535 Aufrufe, 2 Antworten
I have got multiple users experiencing an error with Revit 2021.  A message pops up saying "Colour Fills calculation failed"
then Revit hangs and crashes.
I have updated to the new service pack (2021.1.4) but still having the issue.
Anyone else having the same error?
2 ANTWORTEN 2
Nachricht 2 von 3
RDAOU
als Antwort auf: sham.summan
@sham.summan
This a recurring error since Revit 2013...seen it also/at least in versions 2014/15/18. It could be triggered by various reasons, no one really knows the actual cause (except probably Autodesk Development team)
Sometimes reproducing the color scheme and changing condition from a shared parameter to a project parameter helps, other times disabling the color scheme prevents it from happening.
Having no clue what is in your model, makes it even impossible to know what is going on. Therefore, if you cannot share the model, I would suggest that you report it as a bug and wait for Autodesk's reply
Nachricht 3 von 3
sham.summan
als Antwort auf: RDAOU
Many thanks, let me try and reset the Color Scheme and see if that works.
S
