All Materials in All Views are showing as grey & cannot be overridden
KJH6Z4PH
KJH6Z4PH
Hi !
I've run into an issue where all of the materials in my model, no matter the view, show up as an opaque grey. It seems like some global setting is causing it but I cannot figure out what it is. I don't believe it's a hardware issue because I have other model which display as expected on the same device.
I first noticed when I couldn't make any of the glass show as transparent in 3d, then I realized that I couldn't change any material color or texture, even with graphic overrides. This applies to system families, model-in-place families and normal families all the same.
I've included screenshots, please ignore the unfinished modeling, any help would be appreciated.
Set View Phase Filter to "Show Complete".
KJH6Z4PH
Thank you!
