aligning with detach
jfjacques
jfjacques
The align tool is my friend. I would like it to be a better friend. When moving walls using the align tool (ei:aliging walls to grids) I can't detach the wall. The result is that walls above and below the wall that is being modified also move.  I instead have to use the move tool. Is there a way around this?
cbcarch
That is expected behavior.
Detach the wall(s) first, then use Align.
There is no "Align and Detach" option like there is with the Move command.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Walls are sometimes too smart for their own good.  If it can't be done with Move + Disjoin alone then you can Move + Disjoin, then Align.
Huh? Revit doesn't throw a warning? Something like this?
jfjacques
that's a massive pain, unfortunate for such a key function.
