Ageled roof
Ageled roof
13lemartinez
Message 1 of 16
Ageled roof
13lemartinez
I am trying to a gable roof that is at and angle, but the slope goes up as the angle gets longer, see pictures.
Replies (15)
Message 2 of 16
GustavoUbriaco
Hi!  this corner causes the conflict try to make one single line or if it's necessary to have both maybe the solution is put a slope arrow or split segment.
Gustavo Ubriaco Contreras
Message 3 of 16
13lemartinez
If I do that then this happens.
Message 4 of 16
GustavoUbriaco
how about uncheck defines slope and use this?
Also you can rise another corners if you want some like this
Message 5 of 16
GustavoUbriaco
Here is a better view
Message 6 of 16
13lemartinez
That is a great solution, unfortunately I am working with Revit LT
Message 7 of 16
GustavoUbriaco
that is a great problem 😞 If you want I have revit 2019 and 2021 I can help you to do that easy job 😉 in 5 minutes
Message 8 of 16
13lemartinez
That would be amazing.  this is what I am trying to do.
Message 9 of 16
GustavoUbriaco
Cool could you draw how is the roof here please? and the red ones are like I draw?
Message 10 of 16
13lemartinez
Okay, I have added those roofs.
Message 11 of 16
GustavoUbriaco
I tried to send you a message but I can't if you like let me know if I'm ok or wrong
Message 12 of 16
GustavoUbriaco
do you want this corners at some elevation?
Message 13 of 16
GustavoUbriaco
If you like check in the file and let me know the changes to improve this roof, feel free to let me know please
Message 14 of 16
13lemartinez
That worked.  Thanks!
Message 15 of 16
GustavoUbriaco
Your welcome I'm glad to help you all you need let me know!
Message 16 of 16
Any have company recommendations for re-building roof? I know how to important keep apartment to save, I would like to rent couple small apartment to guest in North Ireland. I found some company who can do that https://litcore.ie/ someone worked with them?
