After Model upgraded from 2018 to 2022 in the error report it says "Can't move element." what is it?
narasimhamurthy8ULAN
Revit Upgraded the model from 2018  to 2022 and some of the eorrors i have found as given below .I want to understand they are any critical model errors are ignoreable.
Error Number 01.Can't move element.
                         02.Equality constraints are not satisfied. The action either violates a locked constraint or tries to modify                                   a sketch based object outside of the sketch mode.
I have element IDs but I nee your suggestions and advises on this to make my model error free to be upgraded to 2022 without anything missing from 2018.
I am checked with element ID for the first error I am found there is no change and nothing has been deleted what canused this error.
eleron96
Based on the errors you've pointed out, it seems that there are two issues at play. Your elements are fixed, which is preventing you from moving them. Try the following:
Error 01: Can't move the element.
  1. Identify the locked elements or constraints that are preventing the movement.
  2. Unlock or modify them as needed to enable the element to move.
Error 02: Equality constraints not satisfied.
  1. Ensure that you are in sketch mode when modifying sketch-based objects.
  2. Check for locked constraints and adjust them accordingly to avoid violations.
    p.s. In any case, I would not recommend jumping from the 2018 version directly to the 2022 version. Based on my experience, it's better to update models incrementally: 2018 -> 2019 -> and so on. This approach reduces the risk of breaking or losing something in the process.
