After Importing the inventor file as revit family, system is getting hang
infoU3JNM
infoU3JNM
We have created the family element in the inventor and saved in the Revit family format. both softwares( revit and inventor) are 2020 version. after created the family the same file was loaded in the Revit architecture file. once the family was loaded and copied as per the project requirement . its take more time while zoom in, zoom out and editing the drawing. In continuous that the following message was appear - "your current session is using more memory than your computer can efficiently support"and closes automatically. Please provide the solution to stop this loading issue.
And also the message appears during rendering. cant able to do the basic rendering.
I imagine this is connected to the content of the Inventor file, generally speaking Inventor models go to a much higher level of detail than a typical Revit family. Importing something particularly detailed from Inventor would definitely lead to a slowdown in Revit.
My suggestion would be to examine the family you've got, see if you can bring the detail down at all, Revit isn't great at showing Inventor levels of detail.
