Advise need - Block wall connection
PrathapSekar
PrathapSekar
Hi Masters,
I need to create block wall as shown in image 1.
But my Revit model is looks like image 2.
Is there any way to get my model like in the image 1.  Please let my know, if more details required. Thanks in advance.
Thank You! and please 'Accept As Solution' when you found a solution, to help others.
Sahay_R
Prathap,
Have you created this with two different wall types? When conventional walls get too close to each other, Revit doesn't really like it, so it refuses to join them and clean them up.
Have you tried to model this part as a model-in-place component in the Walls category? That may solve your problem.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
chrisplyler
I can't tell what is going on in your pictures. Is that whole thing a single family placed into a wall? Window family? Door family? Have you look at the family in the Family Editing environment? What's going on with it?
When you said you want block wall as in the first picture, are you talking about the blue boxes you drew? Which bit is supposed to be block? What are the blue boxes? What is the bit with the hatch pattern?
Kimtaurus
How are the Cut Line Styles defined in the VG Overrides window?
What are the functions of the wall layers? Materials?
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
