Advanced Issue: Curtain wall Ballooning file
-Navisworker-
-Navisworker-
I have a Revit model from the curtain wall sub contractor. LOD is 500, file is 30,000 objects and 170MB.
The file is 2017 but the project is 2016. I opted to export to IFC for Revit Coordination then spit the model to Navisworks for site coordination ( I got IFC to work). Initially the file was too big to export to IFC. This required redrawing 15-20 profiles for curtain wall mullions, panels etc, reducing the LOD and the file to 92MB.
Here is the kicker, usually when a model is exported from Revit to Navisworks, the resultant is 90% smaller in file size. When I export this curtain wall to Navisworks, the resultant is 96MB. No matter what I did in my Navisworks export settings I could not reduced the output file size.
This leads me to believe my the curtainwall itself is too big. I am really running out of options for reducing the file size. Here is a list of things tried:
  • Exported all families to uncover huge family files. Made edits to reduce family size.
  • Purged all families
  • Used DPR Slicer cleanup tool, removed all sheets, views, schedules and legends from the model.
  • Purged the model, numerous times removing everything
  • Removed cad files
  • Created new file. Linked in Curtain wall file, copy paste the model, same issues.
  • Compacted file (numerous times)
  • Exported with a coarse view
  • Exported to NW with these options:
There is something that is ballooning this file and I can't find it. Help??
Autodesk: I have a file I can submit if you want to dig deeper.
Alan.johnson1970
I think the problem is your are exporting as IFC which creates the large file size. Can you not export to NWC?
Also are any of the families nested ? - Nested families will increase file size.
AJ.
-Navisworker-
As stated in the post, I solved the IFC issue and got it to work. I also am showing the export process for NWC. Never have I come across an instance where my NWC export is the same size as the revit file. I suggest rereading the post.
On another note, the post is marked as solved but I don't feel it is solved. Is this a glitch in the forum? I thought the original poster is the one that marks stuff solved.
Alan.johnson1970
This must be a glitch as I didn't mark it as solved.
AJ.
-Navisworker-
Figured out how to reverse it, but it seems it is a glitch.
Alan.johnson1970
Glad that's sorted, sorry I couldn't help more with your export Issue.
Although can you attach the file, I will have a look at it.
AJ.
-Navisworker-
When you doubt, you just have to experiment.
On a whim I imported the RVT file directly into Navisworks and did it not create an 8MB nwc file. Too sweet. Never did find the cause but this is a solution.
