- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
3- How can I adjust the position of the image on the material exactly on the surface... Like If I want the image on the material to be on a certain place or to start with the beginning of the surface its on?!!
u can see the problem in the image attached
there is one solution I use but its bad and hard one
to adjust the position of the image in the material
However that's inaccurate and hard to adjust
beside
I have more than one surface with the same material it cant be adjusted on boss of them
and even with one surface ,, every time u move that surface even altl u will have to adjust the position again
"ps:the image on the material is choose to be repeated vertically and horizontally and if i tried to turn the repeat off it crashes and the image wont appear at all"
