- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi
I have a problem adjusting the height of the Generic_Models_Masonry_Chimney_Wall component in my Revit model.
I load the family and insert it then I edit the heigh using the Edit Type-Duplicate, however the chimney crown stays at the same height and just becomes thicker, see pictures below (I hope they appear in the message).
EDIT: I am working on Revit 2025
Before - Automatic height of 7300
After - Height adjusted to 5000
Has anyone experienced the same problem or knows of a solution I can try? I'm new to Revit so I don't know much about editing families.
