Create a Graphic Tab Model Surface Pattern Crosshatch that is sized the same as the Texture Image and then use Texture Alignment on the Graphic's tab.
Hi @CT36801
Thanks a lot for posting your question to the forums! Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Technical Marketing Manager | Construction
