Adjust Level Line Offset from crop Region by scale or custom settings
edanastas
Message 1 of 22
edanastas
Is there a way to control the Level head offset from the crop region of the view. I'm constantly moving these levels out on sections and floor plans.
This would be awesome to be able to control with a default offset or at least if Autodesk doesn't want to give this control up (why, I don't know), then change the offset depending on the scale.
Let me know if I'm missing something.
Edward
Replies (21)
Message 3 of 22
edanastas
I've used scope boxes quite regularly but that would not solve the issue. Let me try to clarify... If you refer to my screenshot, you will see how the level titles cross over into the drawing. When dealing with large projects it's not an efficient use of time to constantly have to adjust the 2D extents of these level heads when it can be a simple default global parameter.
for example... I would like the level heads to automatically be placed a set page dimension outside of the crop region, such as 6" or 3". This could be a type parameter within the level head family or it could be a single global parameter for the project. I'm showing a section example, but this would apply to plan as well. The parameter exists in Revit, it just doesn't seem to be available for us to customize.
Is there a way of adjusting this parameter?
Message 4 of 22
@edanastas wrote:
...The parameter exists in Revit, it just doesn't seem to be available for us to customize.
What parameter are you referring to?
Message 5 of 22
he said
"for example... I would like the level heads to automatically be placed a set page dimension outside of the crop region, such as 6" or 3". This could be a type parameter within the level head family or it could be a single global parameter for the project. I'm showing a section example, but this would apply to plan as well. The parameter exists in Revit, it just doesn't seem to be available for us to customize."
Message 6 of 22
@Anonymous: I appreciate your participation and acknowledge the "re-tweet", but I have no idea what you're pointing out to me. I am asking @edanastas what parameter he is referring to when he says: "the parameter exists in Revit, it just doesn't seem to be available for us to customize. Is there a way of adjusting this parameter?"
What parameter are we talking about?  That's my question.
Message 7 of 22
edanastas
By "Parameter" I'm referring to the value that defines where it get's placed now by default. It consistently get's placed at a certain distance from the crop region. That distance has to be defined somewhere within the program. It's just not available for the users to set or change.
Message 8 of 22
loboarch
The distance of a level head (or grid head for that matter) is offset from the edge of a crop region is a hard coded value. You can change it by manually dragging, but you can't make it smaller or set a larger distance for the "offset from crop" by default. This value is set at the programmatic level and not accessible to the user.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 9 of 22
...and where it's placed is dependent on the scale of the view.
Message 10 of 22
loboarch
Kind of....The distance is an annotation based value, so it is always the same distance from the crop edge to the end point when printed, say 1" away will always be 1" away when on a sheet.
Jeff Hanson
Revit Help |
Message 11 of 22
@loboarch: Actually, this thread just became more interesting. I wonder whether the bubble head could just be offset a certain distance from the Origin Ref. Plane in the family, and then draw a "level" line between the bubble head and Origin Ref Plane.  That line would connect with the other  "level" line that Revit automatically creates.  What do you think?
...1, Black, Grid Line 1/2" Smiley Wink
Message 12 of 22
What if you have the labels on the other side on a different view?
Message 13 of 22
Answer: a cross between an elephant and a rhino.  Smiley Wink
Message 14 of 22
cbcarch
Read the whole thread here.
I still think a Scope Box is the best method for globally controlling Grids and Levels.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 15 of 22
edanastas
Yes, I think we all agree the scope box is the best way to control this (at least with multi-level buildings), but it doesn't control the offset of the level heads from the scope box (view) crop region.
Message 16 of 22
edanastas
ok, so why not. we want control of it. We have for a long time. It would really help everyone out.
Message 17 of 22
edanastas
That last comment was in response to this....
"Kind of....The distance is an annotation based value, so it is always the same distance from the crop edge to the end point when printed, say 1" away will always be 1" away when on a sheet."
So is there a way to edit that value in the "hard" code at least?
Message 18 of 22
totally agree with the OP
Similarly I spend ages manually dragging these elements as the scope box crop is quite generous
As the size of the graphics are different for each, and maybe the offset is different for each , maybe this could be done via a parameter in each of the respective families to give finer control.
Message 19 of 22
edanastas
In response to
Message 20 of 22
mes
Why not place your text on the other side of the level head? I know the section is opposite yours, but it mirrors on the other side. Not saying that a parameter to control default gaps for levels and grids isn't needed, but in my opinion it is too big and not to small.Level head.JPG
