Just a question if a gaming laptop specs will perform better than a mobile workstation specs? I plan to buy a machine that I'll use for Revit/Infraworks/3DS Max/Civil3D?
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Hi @Anonymous
Please select the Accept as Solution button if my post solves your issue or answers your question. Likes welcome!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
"Gaming laptop", "workstation laptop", and "better" are all pretty vague and relative terms. I can get a "gaming laptop" which will struggle compared to a "workstation laptop", and vice versa.
Nice thing about gaming laptops are they come with GTX cards vs Quadro and usually have the option for dual drives. I recommend SSD for Windows and programs and a HDD for backup files.
Get an i7 or better processor, try to get the best one that you can afford ....500gb+ for the SSD...32gb Ram... GTX 900 series and higher.
Keep in mind, lots of gaming laptops have 4k screens. So you will want to have one or two external monitors to hook up to it if you get a small screen. Post some specs and we can comment. I prefer Sager laptops btw as they can be customized.
...just wandering by and wondering if you are aware that the World Health Organization has added “gaming disorder” to its globally recognized compendium of medical conditions and diagnoses? ![]()
Gaming disorder?@barthbradley really ![]()
Viveka CD
Hi @Anonymous
I just wanted to follow up here, if the posts by the experts helped with your question.
Please mark any posts that help with "Accept as Solution" and thanks! Let us know if you are seeking more information.
Viveka CD
@Viveka_CD wrote:Gaming disorder?@barthbradley really
http://www.who.int/features/qa/gaming-disorder/en/
Yep! I thought I was cured until my mom installed Spider Solitaire on my iPad. I need to get my gaming computer back in operation to play Battlefield to help cure my Solitaire addiction.
by the way i did bought a workstation laptop, here are the specs & please comment what you think.
Dell precision M7510
@Anonymous wrote:by the way i did bought a workstation laptop, here are the specs & please comment what you think.
Core i7-6920HQ 2.9Ghz Quad core CPU32GB DDR4 2133mhz RAM15.6" Ultrasharp UHD IGZO 3840x2160 display256GB NVMe PCIe SSD OS Drive250GB Samsung 860 EVO 2.5" SSD -2nd driveNVidia Quadro M2000M 4GB GDDR5Intel HD integrated graphicsWindows 10 Pro x64 installed
Be sure that you get external monitors to go with... That screen will make Revit look tiny.
Also disable that Intel card as soon as you get it, but yeah, it's a good workstation.
Revit and Autocad want to use one card only...which you will want to be the Quadro. Else Windows will attempt to switch cards on you at different times and Revit/Autocad will crash.
Hi @Anonymous
Did you compare the system requirement with the above configuration?
Viveka CD
A real honest to god moment of truth. I love it.
But let's be real.
It's well qualified.
@Anonymous
Ok, Let me know when you've had a chance to compare the specs
, and @David_Knight
you cracked me up on this busy Monday.
Viveka CD
@Viveka_CD wrote:@Anonymous
, and @David_Knight
Hi @Viveka_CD I did compare the specs to the requirements and I think it exceeds the minimum anyways. Thanks!
Your mobile workstation is very good, spec wise. The minimum specs are quite mediocre, no need to compare them.
@ToanDN wrote:
@Anonymous wrote:Hi @Viveka_CD I did compare the specs to the requirements and I think it exceeds the minimum anyways. Thanks!
Im sorry @ToanDN if you got offended by the comparison
, @Viveka_CD just asked me if I could let her know when I manage to compare them. No biggie.![]()
