addint a new product information
kamaluddin.shaikh9
Message 1 of 8
kamaluddin.shaikh9
hiii,
i am using revit 2017, and i have a question about material related to scheduling.
i want to add a new product information in material browser (identity),
there are 4 product information, (1) manufacture,      (2) model,    (3) cost,    and (4) url,
it is possible to add a new 1
i am attaching a jpeg file for your reference,
Replies (7)
Message 2 of 8
loboarch
You can add parameters to materials, but they will NOT show up in the material browser. You would need to create a schedule with materials and you will be able to see/select the parameter there.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 3 of 8
Sahay_R
Add  Shared Parameters to the objects that carry the material. They will show up in the Schedule.  A material shared parameter would be schedulable, but not show the information from your screenshot. Text parameter will be editable and that is the route that I would take.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 4 of 8
kamaluddin.shaikh9
Thanku very much you both
Bt why autodesk not programme in revit that type of option
If autodesk will programme it or give a option in material browser to add a new product information.
It will very helpful for finalising building estimation
Message 5 of 8
kamaluddin.shaikh9
I request to autodesk they have to do something about it.
Message 6 of 8
Playing devil advocate here.  I don't see a strong reason to add information such as Manufacturer, Model Number, Cost too the material browser.  For very simple example:  re-bars and steel plate may have the same material, but one is priced based on length and the other based on area.  How would you think the cost of steel to be present in the material browser?
The information you ask are already there for building elements, which is appropriate.  Adding them to the material browser is redundant and providing little to no value.
Message 7 of 8
kamaluddin.shaikh9
You are right
Bt how many times I will calculate the value for quantity
Such as area and length
Example
I need complete detail of wall material
So how can I get this
1) total no of brick
2) total plaster area
3)total flooring tiles item in 1 bedroom but 2 types of. Flooring are there
If any idea then suggest
Message 8 of 8
Sahay_R
Create a formula driven shared parameter. For floors, for instance, I would create a formula that takes its Area and divides by the number of tiles per square foot of the surface.
Rina Sahay
