- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a project that I have been working on for a few months now that has 1 Design Option Set set up. In this project we are replacing only the exterior sheathing and finish for the entire perimeter of the building. The studs and interior gyp are to remain. I have this project set up so that the interior gyp and studs are one wall type, and the exterior sheathing and finish are a second wall type so that I could have the exterior finish be demolished and replaced easily. Currently in the project the design option only dealt with the decks, so only the decks are part of the design option (see image). We are just about finished up with CD's and our client has decided to add a Value Engineering alternate to have a different exterior finish for the entire perimeter. I will have to create another Option in this set for the Value Engineering portion, which I have done. My issue is that I am not sure how to go about adding elements to my new design option and the ones already in place. Since the exterior finish needs to be different in the VE alternate, everything hosted on those walls will have to be added to these design sets as well. When I try to add any wall with anything hosted on it (window, door, dryer vent, etc) I get the error message "An insert in the main model cannot be hosted by an element in a Design Option." I have tried isolating a single wall, highlighting the wall and everything hosted on it, and adding it to all Design sets, and I get the same message. I also tried highlighting everything in my model and adding it to all design options, I get this message in this situation as well. This should be a pretty simple adjustment, but it's turning in to a huge headache!! Any suggestions you might have would be greatly appreciated!
FYI, I am using Revit 2020.
Thanks in advance,
Kate
