adding the windows from same file but a earlier version
rclement
Message 1 of 9
rclement
as i would these excercises from this book i saved as different versions according to chapter. for some reason i deleted windows from the first floor
so i would like to get the windows from 6-1 and put them in 10-1
i tried group saved as a rvt file but is also took walls . i just want the windows
how do i do that
Replies (8)
Message 2 of 9
_Vijay
yes, windows wall hosted so it will come along with the wall. if don't want wall you need a new instance for the window. hope it's helpful to you.
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
Message 3 of 9
constantin.stroescu
Open the Earlier Project version
  • click on the window you want to transfer - and then : Mode>Edit Family - that opens the Family Editor - Save the Family into a new .rfa file so to can find it later
Open the New Project version
  • go to Build>Architecture > Window >Mode>Load Family and load the previous saved Window family - Revit will upgrade the family - save it again in the new version and load into your new project
Constantin Stroescu
Message 4 of 9
rclement
so basically it easier to reinstall the windows
Message 5 of 9
lim.wendy
Hi @rclement,
Thanks for reaching out to the forum. Have you had a chance to look over the suggestions provided by @_Vijay  and @constantin.stroescu?
Do you have any questions about it, let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you. ?
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Message 6 of 9
_Vijay
there are several ways to do that if explain your intention with some images I can definitely help you.
Vijayakumar
Head of BIM
Message 7 of 9
rclement
ill have to give it a try ty.if i dont want walls do it in 3d mode?
Message 8 of 9
rclement
basically like a cut and paste in autocad.take say windows from one file hopefully cut and paste to clip board and then open second file and paste in the same place that they were in before
Message 9 of 9
ennujozlagam
you can try this, you can go to elevation view > select/pick the window (only) > copy to clipboards > aligned to selected levels and see if helps
