Adding Symbolic Lines to an existing Door Family - Without moving doors
karl_kachele
karl_kachele
I would like to add Symbolic Lines to an existing Door Family to show ADA clearances.
Adding the actual lines are straight forward. The trouble arises when I reload the family into the project and all of those doors are then re-centered based on the new extents of the symbolic lines. This shifts every door by 9" and causes many alignment issues and errors.
Any ideas of a solution here?
Edit the family and draw the push/pull side floor clearances using symbolic lines then reload it back in project.  That shouldn't shif the door.  Share your family here to see ehat is up with it.
karl_kachele
@ToanDN  That is what I have done. The problem is that the family shifts when reloaded.
See description above.
Can you share the Revit door family?
karl_kachele
Yes
Try this:
karl_kachele
That did it, thank you!
