Adding Room Numbers onto the Walls as parameter
Hi there,
I want to add room number to walls within the boundaries of the room as identity data automatically. I created Shared Parametre named Room Number and assigned to the walls. Generally, I create some wall types to use as plaster, ceramic, wood finishing to put inside of the walls that surround the room like in the image below. Issues about the wall finishings are fixed by this way. And now, room numbers have to be written to its wall elements automatically.
Is there any way to get this? -maybe with dynamo-
Thanks a lot for your times.
What about walls between two or more rooms?
Kimtaurus
I think the Revit Roombook add-in has this functionality.
Dynamo is also a possibility, but it'll take some coding, I haven't found a package which as this node.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
For example, as you can see in the image above, brick wall marked in white is between two rooms. But the walls marked in yellow -my goal is those ones- are not a layer of the brick wall. These independent walls are adjoining to the brick wall to be used as finishing. They should take the number of the room that it belongs to.
Finally, all these walls should have the same parameter number as the room they are in.
Thanks again.
m_fluereci
Observer
Observer
KEEP DREAMING
