Hello Everyone,
I am trying to make a tag that will display the Room Number (or Space Number, I'm not picky) that an element is inserted into. The goal is to use the Room Number as half of an object's identification. The tag would display something along these lines:
101.01
The Red half, being the Room/Space Number and the Blue half being a unique identifier (to be manually set).
It would seem I can't simply insert the "Room Number" parameter into any tag that is not a room tag, likewise I can't seem to incorporate the "Room Number" parameter as part of a model family, even with the Room Calculation Point turned on. Is there, perhaps, some back door or formula I could use to make this happen?
As an aside, we will be working exclusively with inserted DWGs from our clients and we will be placing our own Rooms or Spaces into our own template file so we have free reign to dictate Global Parameters and such. Similarly we could just as well NOT use Rooms or Spaces if there is some other, clever way or making an element report what "container" it is located inside of. Lastly, we aren't married to any particular Family Category so it's no difference to us if we tag a Generic Family or what have you, just so long as the Family isn't an MEP family since we are working with Revit LT at this time.
Thanks in advance!
