Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Adding profiles to floor panels
Homecad2023
Message 1 of 25
Homecad2023
Hi there
I would like to add profiles to floor panels such as bottom plates as shown in attached image.  Not sure the best way of doing this
Thanks in advance
Tony
Replies (24)
Message 2 of 25
Model it the same way it will be constructed in the real world.  What is that element in the real world? Beam? Thickened Edge?
...maybe the Slab Edge Tool could be employed here.
Message 3 of 25
Use slab edge tool with a custom profile.
Message 4 of 25
@Homecad2023 wrote:
Hi there
 Do you mean Curtain Wall Panels?
Message 5 of 25
Homecad2023
In the real world it would be a 2x4 or 2x6 plate.  I guess a slab edge would work but I have no luck in creating slab edges.  Anyone have a good example that applies here
Message 6 of 25
https://www.youtube.com/watch?v=YxX15GHX8Zk
Message 7 of 25
Why incorporate this into the floor as a "slab edge"? Why not beams for this? Seems you'd have a better BIM Model that way.
...are these plates constructed separately from the floor or are they embedded into the floors?
Message 8 of 25
Homecad2023
Slab edge is a good solution however how would you have it as part of the floor instead of always having to add it after
How would you add beams as part of the floor?
These plates are added before the floor gets installed but it might as well be part of the whole assembly since they happen almost at the same time
Message 9 of 25
Are they modular floor panels?
Message 10 of 25
Homecad2023
They could be modular
Message 11 of 25
Well, it's your planning, but if it were me, I'd keep the plates as separate elements. Think phases of construction and disciplines.
Message 12 of 25
Do you have any specs you could share with us about the construction? Maybe photos?
Message 13 of 25
Homecad2023
The construction is basically wood floor joists with a 2x4 on flat around the edge.  I think my original image somewhat explained it
Message 14 of 25
So basically this:
Message 15 of 25
Homecad2023
Yes! now the plates can be 1, 2 or 3
Message 16 of 25
Double or triple sill plate?  Why?
Message 17 of 25
Homecad2023
Long story but site some times prefer the double plates to hide the anchor bolts and on rare occasion some clients prefer the 3 plates
Message 18 of 25
Why not just make the stem walls taller?
Message 19 of 25
Homecad2023
Stem walls?  not sure if I understand the terminology
Message 20 of 25
It's what your sill plate is anchored to.  Google it.
