Adding parameter to level annotation
roscopeco2000
roscopeco2000
Hello I would like to add parameter to my level annotations markers, to illustrate brick courses aswell in brackets. So i would like its to look at level marker and divide by 75mm and show next to the numbers below. Should i do this as a label in the family? i have attached the family
I don't understand.  You want what to "look at" what and do what?
Add a shared text parameter to the label in the family. Then add the same shared parameter to the project and assign it to Levels category.
MostafaElashmawy
Yes you can add it as a new label or edit the current elevation label.
Check below photo
Mostafa Elashmawy
So the bottom lines of the brick are always at 0 elevation? Everywhere?
I rather use that calculated value in a line based detail family so that you can place it anywhere and it still reports the correct rows.
roscopeco2000
yes the ground floor level is 0 and each brick course is 75mm so 10mm mortar , 65mm brick, So doors,windows etc are always in increments of 75mm. A Door is 2100mm = 28 courses etc. Brick layers like to know how many brick courses rather that a distance. I dont  understand what you were on about with a line based option?
Your rows count should based on the dimensions of the walls, not just the top of them.  If a wall starts at the second level @ 10m then how do you count the rows?
