Adding Columns to Duplicate Room Schedule
PhilvK
Advisor Advisor
PhilvK
I’ve added a column for Occupancy Factor and one for Occupancy Capacity to my Room Schedule, but did so on one of my duplicate schedules. Is there a way to copy them back to the Master, or do I have to recreate them in the Master, and if I do, will that mess up the ones in the duplicates?
My guess is [Occupancy Factor] is a non-calculated parameter, and [Occupancy Capacity] is a calculated value.
If it is correct then you can just add [Occupancy Factor] in other schedules from the list of fields. But you will have to recreate [Occupancy Capacity] and re-enter the formula.
PhilvK
Yes, your guesses are correct, and thank you!
PhilvK
I added the Occupancy Factor column easily enough to the other schedules, but I can't edit it. What now?
PhilvK
Nevermind...I've got the Occupancy Factor connected to a Key Group!
