Adding an editable label to keynote family
Sahay_R
Mentor Mentor
Message 1 of 12
Sahay_R
Hello all, Is it at all possible to add an editable field to a keynote tag? Currently we are using Keynote Manager to keynote building elevations. Below the Keynote, we have been using dumb text to add in the thickness of the material - something that makes me cringe. Is it possible to add an editable field where I can type in the thickness after the tag has been dropped in? Thank you!
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Replies (11)
Message 2 of 12
cbcarch
-You could use Keynote set to Text box, and add the material thickness into the keynote text file.
-You could use a User Keynote
-Or, maybe just use a Material Tag for materials?
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 3 of 12
Hey Rina! No, but I'm wondering why a Keynote in this case where you're adding instance information.
Message 4 of 12
Sahay_R
@barthbradley This is an 'inherited' project, which I am attempting to clean up. Keynote Manager was used.
My problem is that I am unable to add a third object to the tag - something which I have been doing right left and center with my other tags
@cbcarch - you speaketh of setting to text boxes - pray, idiot proof details, please?
Rina Sahay
Message 5 of 12
Message 6 of 12
Sahay_R
@ToanDN that's another line of approach I'm taking - for some reason Keynote manager does not show the new keynote after I have created it and so I can't switch values...
Rina Sahay
Message 7 of 12
Understood. Hence the workaround.
Message 8 of 12
Sahay_R
But my tag doesn't see the modified Keynote. In my screenshot you see the edited keynote to the left. To the right you see what pops up when I try to switch my tag over - and my new keynote doesn't show up to switch over to. GRRR!
Rina Sahay
Message 9 of 12
cbcarch
Use a Keynote Tag with Type Keynote Text, in lieu of Type Keynote Number. In the Keynote Text File, add the material thickness.
Then you can show the material thickness "text" in the Keynote Tag
Cliff B. Collins
Message 10 of 12
Are you modifying the keynote file and reloading it?
Message 11 of 12
Sahay_R
hee hee hee @barthbradley - that's the crucial step that I neglected....
Rina Sahay
Message 12 of 12
he,he. been there, done that. glad I got company.
