adding an edge to a polygon mass object
I'm doing a tutorial from the Mastering Autodesk Revit book and it's not allowing me to add an edge to triangulate a surface in a concenptual mass object. The tutorial says to select the face and add and edge to triangulate, but when I select the face, which only selects two parallel faces it only gives me the option of placing a parallel edge. This would only split the faces. I cannot select vertices or "nearest" along any of the edges. Please advise. Thanks.
Regards Peter.
