Area Plan color hidden by slab
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
DanielBush
4861 Aufrufe, 2 Antworten
First off: my area plan's color scheme is already set to foreground.
I have a building with a pitched shed roof adjacent to a flat roof that is lower than the pitched roof. When I do an area plan, the color seems to be obscured by the lower flat slab. When I hide the slab, the color shows up.
Here is the area being obscured by the lower slab:
And here is the same view with the slab temporarily hidden:
Any ideas why a slab would obscure an area, even when the color scheme is set to foreground?
Thanks for any advice,
DB
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: DanielBush
Does the slab has its surface pattern set to solid white (by any means such as category override, filter override, element override, or phase filter)?
Nachricht 3 von 3
DanielBush
als Antwort auf: ToanDN
I didn't think that would have an effect, but it did. The slab surface is plywood and it had a solid fill of white applied to the material. I assumed that area fills would in effect be above whatever pattern is in the material but I was wrong.
Thanks for helping us with this!
DB
