Adding a comment to a selection
Dear All, I am in hurry as i am submitting a project, my project is a mirror of 3 villas and i want to Comment on each by its name, but when i select the whole villa, i don't get the comment option
ennujozlagam
hello, what do mean you want to comment? you can use annotate > text. thanks
The built-in Comment Parameter is an INSTANCE Parameter. Not every element  has a Comment Parameter. You have 130 elements selected in your screenshot. You need to Filter out those elements that to not have a Comment Parameter.  Use your Filter Tool and remove those categories from the selection set.
jammes1939
Community Visitor
Community Visitor
Hi, it sounds like you’re trying to comment on individual villas, but the software is only recognising the whole model as one object. In most design or BIM tools, you need to group or tag each villa separately before the “comment” option becomes active. Try breaking the villas into individual components or assigning unique IDs/names to them — after that, you should be able to add comments to each one by its name.
I faced a similar issue while working on a file-sharing project, and organizing the elements first really helped. If you ever need to manage or share large project files more easily, you might also find terrabox player useful.
