Added material to wall
jillL24YD
Observer Observer
Message 1 of 8
jillL24YD
Observer
Observer
I made a generic concrete wall and it is adding a material in section and I don't know why since it is not in the wall it's self.  Anybody know what might be causing this?
Replies (7)
Message 2 of 8
nozci
Your wall material will be between wall boundaries. It is normal.
Message 3 of 8
azad.Nanva
use the surface material:
Message 4 of 8
jillL24YD
Observer
Observer
I only have one material and it is the right width. It is adding an addition material making the wall thicker.  I have never had this happen before, that's why I can't figure it out.
Message 5 of 8
jillL24YD
Observer
Observer
I have the surface and cut material set to concrete.  It is only showing up in section view.
Message 6 of 8
nozci
Did you measure your wall thickness on the pan view?
Message 7 of 8
azad.Nanva
post your material element like me.
Message 8 of 8
jillL24YD
Observer
Observer
