Add reference planes for measurement to family
cbt990
cbt990
How do I add an invisible reference to this window family so that I can dimension to the centerline? the line running through the center currently is just a model line that I added because I knew it would always be visible. I will delete it once I have the window placed correctly, but then my dimensions wouldn't be valid anymore.
So I am trying to have this center line pop up as an option for dimensioning.
Thanks for the help
Revit is amazing
In the Window Family add a Center Ref. Plane and make it a "Strong Reference" under the RP's "Is Reference" Property.
...I'm surprised it doesn't exist already.
...BTW: you can make any RP pickable in the Project environment (for dimensioning, aligning, etc.) just by using an Is Reference other than "Not a Reference".
syman2000
Why not use invisible line inside the window family? That way it won't show up but it is still there.
