Add-in assembly not found (Revit 2020)
9 ANTWORTEN 9
Nachricht 1 von 10
bekj26848
979 Aufrufe, 9 Antworten
I get this two messages when I start my Revit 2020.
Pictures added
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: bekj26848
whats your question?
it tells you what the addins are
Nachricht 3 von 10
bekj26848
als Antwort auf: Anonymous
I dont know how to fix it. I dont know what it is.
Nachricht 4 von 10
bekj26848
So you dont have a solution?
Nachricht 5 von 10
syman2000
Check this webpage. Most likely you need to repair or reinstall your Revit
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Nachricht 6 von 10
bekj26848
als Antwort auf: syman2000
The first one I have found out.
But the last one will not be fixed. I have reinstalled the program 3 times now!
Nachricht 7 von 10
bekj26848
And the second link you have sent, that is not the same problem, which I have posted
Nachricht 8 von 10
michael.coviello
Hello @bekj26848
I understand you were able to solve one of the "Failed to Initialize" warnings but not the other for eTransmit.
In this article that @syman2000  mentions, Does this help to solve the problem.
If this does not help, Please post back.  Thank you!
Please see step #5
  • Revit eTransmit is in the folder: RET.
"Failed to initialize the because the assembly does not exist" when launching Revit
Michael C
Technical Support Specialist
What's New in Revit 2023 | Autodesk University | Revit Blog
Nachricht 9 von 10
bekj26848
als Antwort auf: michael.coviello
Hey @michael.coviello
No the article @syman2000 mentions didnt help, that have nothing to do with the problem at all! And I will recommend that @Anonymous dont answer people, with that bad answer. So I have not got a solution from anyone here from autodesk or forum, or what you call this. And it have been alot of days, with no help in here!
But I have found a solution. The school support could help me, and it only took one try. And not alot of things, I cant use to anything.
So all in all, a pretty bad experience, from a program there a used all over the world!!
Nachricht 10 von 10
michael.coviello
Hello @bekj26848
What was the solution you found?   Please share your solution to the issue which will help others with the same problem find what worked for you faster.
Michael C
