& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
I get this two messages when I start my Revit 2020.
Pictures added
I dont know how to fix it. I dont know what it is.
So you dont have a solution?
Check this webpage. Most likely you need to repair or reinstall your Revit
The first one I have found out.
But the last one will not be fixed. I have reinstalled the program 3 times now!
And the second link you have sent, that is not the same problem, which I have posted
Hello @bekj26848
I understand you were able to solve one of the "Failed to Initialize" warnings but not the other for eTransmit.
In this article that @syman2000 mentions, Does this help to solve the problem.
If this does not help, Please post back. Thank you!
Please see step #5
"Failed to initialize the because the assembly does not exist" when launching Revit
No the article @syman2000 mentions didnt help, that have nothing to do with the problem at all! And I will recommend that @Anonymous dont answer people, with that bad answer. So I have not got a solution from anyone here from autodesk or forum, or what you call this. And it have been alot of days, with no help in here!
But I have found a solution. The school support could help me, and it only took one try. And not alot of things, I cant use to anything.
So all in all, a pretty bad experience, from a program there a used all over the world!!
Hello @bekj26848
What was the solution you found? Please share your solution to the issue which will help others with the same problem find what worked for you faster.
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
