Hi there.
Select your door and check the button Edit Type. When you`re there, you`re at the type properties window. You will see the door and frame materials.
That door family you are using is a standard family of Revit. To schedule correctly your door materials, you would have to:
- change the family single flush (by clicking at the button Edit family); or
- make another door family applying the informations and parameters as you like.
Observe that the parameters Door material and Frame material are not listed at the Schedule list of possible parameters. This happens because that two parameters created at the family are not standard parameters for Revit, so the Schedule system is not prepared to read them. But, one solution is using shared parameters. If you like, take a look at this article explaining shared parameters: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN...
If your problem has been solved, please click on Accept as Solution. Then others users can take benefit of it.
Felipe Góes
Autodesk Instructor
