Adaptive Family Rotation
orhan_ertugral
orhan_ertugral
Hi all,
I create a 2 point adaptive family. I put on a reference line points. Points are hosted on a reference line. "Where I get the line AutoCAD 3d spline" I create a divided path then draw 3D spline reference line  When I place on a family some points family get rotate like this. Why rotate some answer me ASAP its urgent!image.png
Did you use Repeater tool?
orhan_ertugral
Repeater tool is not active when I select both of them. But I must place on a different measure betweens are points. My points place like a 2m-4m-4m-3m-4m-4m-2m I can't use a divided path.image.png
I finally work Repeater tool but a solution like this I very sad about that situation image.png
What about overlapping Divided Paths?
orhan_ertugral
Here is the solution;
I create a surface with one line or two lines whatever u use and divide surface  and use divided surface points for the place family strange but work
Another case is solved
