Adaptive Family Reporting Parameters - Errors
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am working in an adaptive family and I want to drive the dimension of an embedded family with a reporting parameter.
I am able to do this if I make a reporting parameter going from the edge of the adaptive grid. I can take this dimension as a reporting parameter and feed the embedded window height.
However, if I try to create a dimension that is a reporting parameter from a reference point or a reference line, it gives me the error message: 'A reporting parameter can be associated to an element property only if its dimension references are all to host elements in the family'
There is an article about the topic here:
It says:
A reporting parameter can be used in a formula only if its dimension references are to host elements in the family (such as levels, curtain panel boundary reference planes). If any of the dimension's references is to family geometry, the dimension can be labeled with a reporting parameter, but this parameter cannot be used in formulas.
In this case, I am not snapping to geometry, but to reference lines and I do not have access to reference planes in adaptive families. Is it normal hat this does not work? Is there anything else I can snap to as a reporting parameter?
I am trying to have the window opening determine the window height size.
