Adaptive component Family: In place mass sweep disconnects from one corner
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
I'm running into an issue with an adaptive component used in an in-place mass sweep. I’ve created a sweep by selecting a profile and a path within a massing environment, and everything seems to work fine initially. However, after finishing the mass or making some edits, one corner of the sweep—typically at the start or end of the path—becomes disconnected or misaligned.
The adaptive component is hosted correctly and snaps to the path, but it appears the geometry is not maintaining its connection at one of the corners after regeneration. It’s as if the sweep partially detaches or warps slightly, only on that end.
Has anyone encountered this before? Is it a limitation of adaptive components within in-place masses, or is there a better workflow to ensure the geometry stays connected properly?
Any insight or workaround suggestions would be greatly appreciated!
Thanks in advance.
