- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When I click ID on a point in the Autocad survey file it shows the correct coordinates based on the Indiana State Plain system we are using. I link the file into a brand new clean Revit file then click on "Acquire Coordinates". If I do a spot coordinate for that same spot I checked in ACAD, the coordinates do not match...in fact its exactly double in both directions.
I drew a line in CAD from the origin to a point on the plan, saved and reinserted the model into Revit. When I check the coordinates initially in Revit they are correct but when I hit "Acquire coordinates" the issue arises again and the coordinates are off by double again. Why does ACAD show the correct coordinates but its wrong in Revit after using "Acquire Coordinates"? I've done shared coordinates many times and never have seen this issue.
The image attached is of the plan in Revit showing the line I drew. The blip in the upper right corner is the survey info. The lower left corner is the origin. The numbers shown in the lower left are what it should be reading in the upper right. Instead the upper right is double the numbers shown in the lower left.
